1 - 20 of 27 Posts
I am currently using an untouched OTS map: the Stage1+HKSPF_93_MRv108. I occassionally switch back and forth between the 93 and the 91oct map depending on what is available.
i just downloaded the new beta for Accesstuner Race that allows me to adjust the throttle limiter on my MR. Would I be correct in assuming that one of the experienced tuners here could tell me what values I could put in what tables to appropriately reduce (not completely remove) the effects of this limiter while leaving some degree of safety. If there is anything else that I could touch or edit on the OTS map I would be curious to know. I would think that someone could simply post up some screenshots from ATR with modified tables and that one could just edit. Obviously not every table because every car is different and logs would be required but I don't know why this process couldnt be an option with some things. Let me know, please.
I asked the very same question about a month ago... Although it may seem like we have alot of parameters in ATR, we cannot change the toq limiter yet... Or that's what Cobb told me, obviously they could do a tune for you.. But currently your are not able to
Yeh the new beta update came out for our 2008-2010 years, an we can now remove the limiter, I had Jon do mine, but i also dont see where it is in ATR
Your right I just saw that post. Sorry. I just PM jon to ask him
How to do it. If you figure it
Out before me
Pm and I will vice versa
Hey guys,
I am trying to do the same thing for my 08 mr running ots stage 2 hkspf 93 lwg. So far the tables look much different than what was described for evoscan. Can you send me any help?
Thanks!
Never mind, I hadnt updated to the beta version, now I see the proper table.
Is anyone adjusting the boost limit in 1st gear to keep from shooting metallic objects out of the bottom of our cars?
Hey guys,
Thanks!
I uploaded the new beta maps go out for a spin, p1235 code. I pm Cobb. They said disable the code. I try again and my cars goes into super limp mode. Clear the codes... Still in limp mode. It took 3 resets before my ECU finally reset. So just a word of caution before putting these maps on. My car went crazy. And I WILL NOT be touching these maps until further progress has Been made with the beta
open yout tune
then open another map in a seperate program (atr)
press CTRL K which will put it all back to stock
copy and paste over all your maps from TUNE to STOCK
CTRL F and disable all the P12XX codes and the ACS off and Lean spool
save map flash map profit
and if you did NOT install the BETA software to a NEW FOLDER (IE: NO THE ONE ATR WAS ALREADY IN)
RE INSTAL your software to a NEW folder and try again
Could I just open an OTS in the beta, disable all codes and ASC and lean spool and I'll be gravy? I don't follow why I have to copy from
Window to window?
Window to window?
Do what i said and it will work. Or try other stuff and have it maybe not work up to you! :neener:
interesting. I would they would just upload new 1.09 maps!
Is there an easy way to copy all of the maps over? Or do I have to go through each table and manually copy paste?
Ok so I disabled the codes, lean spool and ASC. I'm not going to lie I couldn't figure out and easy way to copy all of the cells back and forth, and there were way too many tables, and I thought I had a better chance of actually screwing up the copy and paste. so I just opened the Tune in ATR, and disabled everything. Took her out for a spin. Everythings great! Limiter off No CEL, jon, thanks for your help
ok so i disabled the codes, lean spool and asc. I'm not going to lie i couldn't figure out and easy way to copy all of the cells back and forth, and there were way too many tables, and i thought i had a better chance of actually screwing up the copy and paste. So i just opened the tune in atr, and disabled everything. Took her out for a spin. Everythings great! Limiter off no cel, jon, thanks for your help
sent from my autoguide iphone app
wahooo
1 - 20 of 27 Posts
