So i have been trying to take this turbo out since 8am.. it is 4:30pm now.. I keep on getting stuck some where and now finally held up pretty good... I have 1 bolt on the bottom of the turbo for the huge line that runs into the turbo, and then I have the bottom bolt that runs off the hot side of the turbo and mounts to a bracket that is also under neath the turbo... the manifold is off and all of the banjo bolts are off also.. I cant get the huge line off because it is directly under the turbo and cant seem to get to it any where. and the other bolt that is held on by a bracket you can see a tiny bit and fit a wrench onto it, which I have been trying for the past hour or 2.. But the bolt is almost stripped.
Also, the Huge line running out of the turbo runs into the bottom of the block and I took the one screw holding it into place but the line doesnt budge at all....
Any help would be greatly appreciated.. All I have is the bottom bracket bolt left and 1 bolt that holds the big line into place.
NEW PROBLEM! Anyone know how much this clip costs or whole housing??
