1 - 3 of 3 Posts
New to the AP world, was wondering if someone could take a peak at these datalogs and see if anything looks out of the ordinary. Was spiking to around 26 psi on the stage 1 93 v403 tune. Reflashed to the LWG tune and now I'm around 24psi, which is slightly higher than the map calls for. Car is completely stock with the exception of a custom cat back. Stock air box with stock filter. Just not sure what I'm looking at so any help would be greatly appreciated. Thanks in advance!
Hey,
Seems like it’s fairly common to see overboost on these maps.
I’m running the Stage 1 CHFF 93 map and was seeing a peak of 26ish as you are in the summer, but right now in this colder weather here in Canada I’ve seen 28-29 ocationally. Kinda spooks me but I’ve had people tell me it’s common. I’m still looking to see anymore info. Other than that everything else seems to be perfect with this map.
- it could also be because I have a K&N filter and not the COBB one specified.
A slight boost spike seems to be common, and is not the same as overboosting. Ss long as it tapers down and holds boost closer to it's target value.
1 - 3 of 3 Posts
