1 - 3 of 3 Posts
So I just installed an hid kit with relay harness. The lights worked fine after install. I then drive 10min to work and try to turn them on while the car is running and they won't turn on. When I flip the switch back to parking lights and off (drl) I hear a buzzing sound, then all the way on the buzzing goes away. If I turn the car off for a second and back on I can switch the lights on like normal. Any ideas what the problem might be? Thanks
I've had a bad HID bulb before. It'll light up the second I flip the switch to ON and then 3 seconds later it dies with a constant buzz. If I flip the switch to OFF and then back ON, it'll turn light up again and then same thing happens.
1 - 3 of 3 Posts
