Running into a little issue.
I can run 27psi all day with no issues on my black.
When I try to run 28psi, I'll end up getting an overboost CEL (P0234) even though I shouldn't.
- My target boost is 28.2psi. My actual boost is ~27.8 (this is on purpose - for now).
- In the logs, my WGDC correction is zero. I set it up so it will only reduce WGDC if I overboost, but it won't add it if I underboost.
- My max load values are all as high as they can go (319), so that's not the issue.
- The only thing I have left to do is to increase my boost cut timer, which I really don't want to do. I have it set to 1500ms right now, which I'd prefer to keep.
