HKS B.O.V Question
2242 Views 5 Replies 5 Participants Last post by  thebigjones
I installed a HKS blow off valve on Saturday among with other things and it seemed to be working perfect, come yesterday morning it was releasing whenever the turbo boosts and there is absolutely no power to the engine.
Anybody know what is going on here?
Any help would be highly appreciated.
1 - 6 of 6 Posts
did you check all the vacuum connections to it?
I checked all of that, I was told to use the recirculation kit or adjust the spring inside the blow off valve to less boost and that would fix the problem. Anybody know how to adjust the spring for the SQV 3?
Garbage bov...no offense.
I suggest the Synapse. Check connections
The HKS BOV is a "Pull-type relief" design, meaning that the boost pressure acts to keep the valve seated. If everything functioned with the BOV previously, then something has gone wrong, and whatever went wrong may not necessarily be your BOV.
In regards to the BOV, I would check the sensing port and the line attached to it. This style of BOV will not operate properly if the sensing line is compromised (even a minor puncture) or if the line is not properly connected.
The previous posts asking you to check your boost fittings and lines are spot on good advice, as you may have a boost leak in your system somewhere. Also, I recommend inspecting your wastegate assembly (not just the lines), if something is wrong back there, it will affect your ability to make any boost.
Edit: I don't believe there is a user adjustable spring on the HKS BOV. Perhaps you or your advice giver is mistake, as an adjustable spring is often a feature of the other blow-off valve design, "the push-type," which I believe is the most common type of BOV used.
Re-edit: If you do suspect improper operation of your BOV and don't know how to set it up properly, you can always re-install your stock BOV. By doing the switch and testing, that will indicate if your new BOV setup has somehow gone awry.
Good luck.
1 - 6 of 6 Posts
