You do plan on recirculating it, yes?I want full exhaust and SSQV. I had their SSQV on my previous car and I love the sound![]()
Already out in Japan, shingo-san~I will get the intake soon as it comes out!
Center pipe now available in Japan!Yes, it is for the axleback portion. The mid-pipe just finished development and should be available shortly.
If you mean the BOV then no, it's gone with the old car. I'm gonna have to get a new one.You do plan on recirculating it, yes?
He means set it to recirculate and not vent to airIf you mean the BOV then no, it's gone with the old car. I'm gonna have to get a new one.
SSQV doesn't recirculate, it vents into atmosphere. And I've seen quite a few pictures of X's equipped with SSQVs. So, unless there's a specific reason to recirculate air (like with BMW 335, for example), this shouldn't make any difference.He means set it to recirculate and not vent to air![]()
When is coming out to america? Badboy san~
I believe so, I'm sure he will poke back in soon.Mind explaining why? Is that because MAF sensor reading will be messed up?
When you vent to atmosphere you risk stalling out b/c you are disposing of metered air. The Evo X already runs pretty rich, I would not give up any of that precious oxygen, despite the fact that it recirculates prior to the MAF sensor, I still wouldn't do it.SSQV doesn't recirculate, it vents into atmosphere. And I've seen quite a few pictures of X's equipped with SSQVs. So, unless there's a specific reason to recirculate air (like with BMW 335, for example), this shouldn't make any difference.
Now, BadBoys question kind of implies that I should be recirculating. Mind explaining why? Is that because MAF sensor reading will be messed up?
The very same reason we had to recirculate it on the VIIIs and IXs is the reason it needs to be recirculated on the X: the mass air flow sensor. As air passes through the mass air flow sensor it is metered by the computer to allow a corresponding amount of fuel to pass through the injectors. By allowing the charged air that is 'waiting in line' to evacuate the system and not be recirculated, there will be a gap in the 'line' and the air fuel ratio at that gap will plummet to a point that the car will bog due to the overly-rich condition. Some cars have even been known to stall at a full stop. In the VIII & IX HKS used the EIDS system to compensate for this, for those people who just had to have a songbird living under their hood. HKS also offered an alternative in the form of a recirculation kit that was specific for the CT9A. One of the reasons you don't hear the factory blowoff valve is because of the heavy presence of factory piping and the restrictive airbox. When switching to an open element filter, even though recirculated, the sound of the blow-off valve was evident.SSQV doesn't recirculate, it vents into atmosphere. And I've seen quite a few pictures of X's equipped with SSQVs. So, unless there's a specific reason to recirculate air (like with BMW 335, for example), this shouldn't make any difference.
It actually recirculates after the MAF sensor.When you vent to atmosphere you risk stalling out b/c you are disposing of metered air. The Evo X already runs pretty rich, I would not give up any of that precious oxygen, despite the fact that it recirculates prior to the MAF sensor, I still wouldn't do it.
*poke* *poke* *poke*I believe so, I'm sure he will poke back in soon.
