1 - 8 of 8 Posts
Anyone run a 285/30/18 with the RPF1 9.5 15 offset? I curently run the 275 but they are very close to the coilover. Want to buy 4 new ones for next season, Thanks.
Put a 5mm spacer on.
I run 265 R1's on the same wheel and was thinking about going to a 275. How close are they?
Discussion Starter · #4 ·
Spacer will put me 7mm closer to the fender and I don't want that. I have been rubbing a little on the fenders with the 275's.
My fenders are pulled and I also raised my car up for more clearance. I'm only lowered 3/4 front and 1/2 in the rear. On the track it actually feels better not being so low.
If you have coiloves, just run a shorter spring. That way the perch is above the tire, so you can go in. You may have done this already for all know.
1 - 8 of 8 Posts
