1 - 20 of 78 Posts
We have Hotchkis in stock and ready to ship!
Mitsubishi Lancer EVO X 2008+ Hotchkis Sport Swaybar Set
Model Number: 22440
Your price is $355.00 Shipped in Continental U.S.
Click here to order!
Features:
• Lightweight, Durable 1 1/4" (32mm) Tubular Front Bar 2 Way Adjustable, +50%, 70%
• Lightweight, Durable 1 1/4" (32mm) Tubular Rear Bar 3 Way Adjustable +155%, 195%, 245%
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your Evo X
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
Additional Information:
Enhance the cornering performance of your EVO X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the EVO X has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets.
See a video of stock vs Hotchkis sways! http://videos.streetfire.net/video/EVO-X-Sway-Bars-Stock-Vs_202150.htm
We will be here when you are ready. These were back order for over a month but we just got a ton of them in.
Thanks again and look forward to helping you with your part needs in the future.
Have a good weekend!
What is the difference between these and the stock ones on a MR? Size, proformance or just color, what does the 355 dollar difference get me? Thanks
Discussion Starter #5
Adjustability for stiffness and also are 32mm. I will add the full write up in post #1.
Thanks!
*droool*
aka gg09gts
i understand these will stiffen up cornering ability, but will it also create a harsher ride over bumps and broken pavement?
1 - 20 of 78 Posts
