I got it with my cams at idle, but it got tuned out. I never get it anymore.How often u guys get p0300 multiple cylinder misfire?? Had it last year and I checked spark plugs which looked fine but replaced with new one..I got the code today.. Does light weight flywheel really throws the code??
What kind of clutch and flywheel do u have?I get it once a month...I do have aftermarket clutch and flywheel which I believe gives the phantom code...plugs are fine too
I wAnt to know too..I get it every once in a while. Maybe every 1-2 weeks. I have a triple and a light flywheel. Car runs fine. Plugs look good. It's a random misfire. what I want to know is what is picking up the misfire, what sensor?
ACT clutch and RRE no name fly wheelWhat kind of clutch and flywheel do u have?
You drive your car?Almost everyone w/ a lightweight flywheel and aftermarket clutch gets the code. You usually get it when puttering around with stop lights and such, never when driving aggressive. Its just from the flywheel. I get is almost every other time I drive my car casually for more than 10 minutes.
i said every other time I drive it. Thus, i've gotten the code 3x in the past yearYou drive your car?
I get it every few times I drive mine as well
