1 - 20 of 61 Posts
WARNING: DO NOT USE ON MR/RALLIART
Incomplete: Updating as I go.
  • Operating System Used: Windows 8 x64
  • Time it took: 2 -3 hours depending on download speed
  • Minimum 30GB of space required.
What this module can change:
  • Disable TPMS
  • Disable DRL
  • Enable Auto-Lock with Vehicle Speed
  • Re-Calibrate Speedometer with different size tires.
  • much more..
Links
You will want to copy DiagBox 7.02.ISO + the three update files from the CD or download them from the link above to a new folder on your desktop.
If you have Win 7/8 you should be able to mount an ISO image without an additional mounting software. If you need an ISO mount software Daemon is included on the CD. You'll want to mount DiagBox 7.02 ISO - make sure to have your laptop plugged in at this point. DiagBox will not install without it being plugged in. Mount the image.
Install & Activation
Run the setup.exe. Once it's done you will get to the activation screen, select the third option.
Then enter this customer code: 1234567
Hit the green button again and it will start installing Lexia & PP2000 (tools). This will fail if you don't have the required free memory. Once done hit the green button again until you get here:
Enter this information: 6 1's in Address; 8 1's in Post Code & Car-Phone
Select the X on this screen & start working your way out of closing the program
Updating DiagBox
Reopen the DiagBox.exe that's now installed on your computer. It will update itself to v7.02. Once that's done close it.
Now we need to copy a file from C:\AWRoot\bin\fi called "APPDIAG.SYS"
Paste it on your desktop & save it for later.
Now we start running the update files one by one. Meaning after an update installs, run the new DiagBox.exe and wait for that to finish the update. Rinse & Repeat until you get to v7.30. The access code for these updates is "scary01". I restarted my computer after every update but you can install them back to back. Up to you.
After the last update to DiagBox 7.30, restart the computer. Once booted back disable your internet, and move your saved "APPDIAG.SYS" back to C:\AWRoot\bin\fi. Run DiagBox.exe & connect the cables to your laptop and OBD2 Port.
DiagBox 7.30
At this point we'll go into the car's ETAC. Don't worry, as we haven't applied a patch yet to let you write. The zip file with the patch will be attached but please don't patch until you do a run through/practice run of the software to get used to it and to know what to watch out for.
Select Citroen > C-Crosser or Peugeot > 4007 - I tend to go with the C-Crosser.
I have to stop here with DiagBox because I don't have the car atm. - A tip if you're doing the install before this How To is done: the "Green Check" means "select" - the "Double Gears" means "write" - to go back there will be a left arrow on the bottom left.
There will be a pop up where the last line of it says "Do you want to automatically configure..." SELECT THE RED "X" NOT THE GREEN ARROW.
Here's a quote from another forum to get to the ETAC for now.
Here are my steps so far. Items I selected are highlighted in blue.
Start Diagbox program
Peugeot (Citreon)
4007 (C-Crosser)
Validate VIN (Check mark)
Diagbox
Repair
Global Test runs
Built-in System interface (BSI)
ETACS_SUV? screen
Configuration
Manual Configuration
Switch on Ignition' screen
Check mark
Vehicle Configuration
Programming By Default
Screen says:
There are two ways to configure list of default parameters:
Do you want to configure the default parameters automatically?
X
TLCD Patch
CAUTION: Again, please make sure to practice using the program to access your car's ETAC before applying this patch.
Download the TLCD.zip file attached. Open it up (if you need a rar program I recommend 7zip) and extract TLCD.exe to C:\AWRoot\dtrd\comm\XMLTLCD. Once extracted run the exe and it should delete some files. At this point you'll be able to bypass the Service Tech Code to write. Again please "X" out when the popup "Do you want to automatically configure.." each and every time. Also always run the program while disconnected from the internet as it will try to automatically update and configure your car.
Rserved
Discussion Starter #5
Thanks, and your welcome! lol...I'm getting the car tinted right now so I don't have my car. Hopefully things are clear as this is my first true How To
aka 1990ggsxnj
Happy to see that you came through with this, xFonts. Quick Q - will you be adding the additional things it can do to the list above once you have the majority of it done?
Discussion Starter #7
No problem man. I'm thinking I will. There's been some things that I'm scared of changing or just don't work. I emailed vadimus to see how we can recover everything back to normal just incase, i'll post that up as well. I know it has to do with the C:/oud folder.
This is pretty cool, sub'd for more info. Did you happen to find out if you can keep TC off by default? Also do you have to have the OEM nav screen for this, since I seen in your other thread you were changing the settings through your nav touch screen.
For TC it looks like you can only fully disable it. I have to look through it again to confirm. You won't be able to have it on and just have it straight to ASC Off though. Once you disable it you won't be able to toggle through it on, off and off. Again, I'll double check in a few though :)
You don't need the OEM Nav to change anything. The OEM Nav just let me change things after I started messing with it, but it isn't a prereq as you can just change it with your laptop and DiagBox
Has anyone tried to see if this will connect with a Tactrix? The only reason I ask is because in the SST Update thread, they have successfully been able to flash the SST using the MUT III software but using a Tactrix instead. So I was curious to see weather that same thing could be used with DiagBox now that we have the files to use.
Discussion Starter #11
Updates have been made, and I will be continuing to update it. If something is missing recheck the thread for any updates. I've reinstalled this like 10-15 times to make sure I get everything I need.
Installation part should be covered.
I think people have tried but it doesn't work. I don't really think it's a high priority, I'd rather the SST thing be done lol.
I got pretty far with this. I can write different firmwares to the cable etc, but in the end it won't recognize that it is connected to the car. I'm going to start from scratch and give it a go. Being in IT this drives me apeshit to not figure it out lol.
Discussion Starter #13
Are you talking about the Tactrix Cable?
I'm going to double check what firmware I have. I don't remember having to do anything else to drivers to get it to work.
No sorry I'm talking about diagbox. As far as I can tell it is working 100% perfectly on the pc end because I can write to the cable, change drivers all that. It just never autodetects the VIN of the car, which means its not detecting the etacs. I really don't know why.
Discussion Starter #15
I don't know why that wouldn't work either. I know at first it wouldn't read the VIN but I just kept attempting it (select C-Crosser, no VIN, return, select C-Crosser again) until it picked it up by itself. I'll double check if there is a specific driver installation.
Discussion Starter #17
would this thing be able to reset the sas and abs ?
Sorry I'm a bit confused.
Once you disable it, you basically set it to off and off with no way to go to off or on, correct? Also, do the lights come up on the dash if you disable it?
Discussion Starter #20
My honest answer would be I don't know, but I feel like someone has done this. I'll have to double check.
That's my bad, I usually explain things in a confusing manner, but yes you are correct. The lights won't show. I'll have to double check this though as I haven't played with the settings.
Just found out that you can change the "tire circumference" which recalibrated my speedometer to read correctly now. Don't know if it changes anything with the S-AWC system yet, though my turns have become more "lively". Placebo effect? Maybe.
1 - 20 of 61 Posts
