Which is why I am having a shop do it. I am done climbing under a car on ramps and stands.Its a very, very messy job.
My time is worth more than 1H mech fee. Besides, I also have a couple seals leaking too from my clutch install that needs fixin.I guess i should have taken pics when my friend and i replaced my boot, but he did it so fast, it took only like 30 minutes lol
Who?I guess i should have taken pics when my friend and i replaced my boot, but he did it so fast, it took only like 30 minutes lol
Just a long time friend, helps me with the shittier jobs or things I'm new to.Who?
Damn. I would like to know how he did it in 30 mins, lolJust a long time friend, helps me with the shittier jobs or things I'm new to.
Damn, that guy is a machine.He works on a wide range of cars, so i guess thats why it was so fast. We were installing an RCA kit in the process so everything was all taken apart. Remove strut, remove caliper, hang it on some wire, remove the "crown nut" thing - i don't know what its called.. then he removed several other bolts back there ( i went on a beer run at this point) then literally yanked it out lol - oil all over the fucking place - but he did it pretty fast. At first he was like "Man, this is a 3 hour job.. if youre a pussy."
So the removal of the joint took like 10 minutes, 15 min for other stuff around it in the way.
But yea, 5 minutes later we carefully took off the boot, cleaned it up, got a new boot on - squeezed in the grease while holding the rubber boot in such a way that it created a suction effect - then clamped it back on with the supplied clamps it came with - took another 15-20 min to get everything completely put back together (cv joint, caliper, strut, wheel, off stands and on the way to the rack to get it re-aligned.)
Yeah he removed it, just yanked it out lol - you have to cause you have to put on the new boot + grease and clamps etc.Damn, that guy is a machine.
Did he pull the axle out of the diff?
Ok. I'm guessing when he yanked it out is when the fluids went everywhere?Yeah he removed it, just yanked it out lol - you have to cause you have to put on the new boot + grease and clamps etc.
I think you'll find some pictures and help in here:hey guys, bumping the thread- anybody learned how to remove the cv shaft from the t case? I tried gently tapping it and prying on the black (rusted in my case) part of the shaft with dimples and it won't budge. If I were to yank it out it would rip the boot, and that's a no go. Should I get a pry bar and pry it with that?
