So I just installed some ID1000's and I've got them dialed in pretty well and the LTFT and STFTs are within +- 5%.
I've noticed that when using the recommended latencies the car was EXTREMELY lean and almost dying, the AFRs were lean off the max of the wideband. I dramatically increased the latencies and it solved the problem and everything seems to run, well, about perfectly now. I'm just wondering if this is common or if this may be an indication of an issue with these injectors, my latencies are literally DOUBLE what the recommended manufacturer latencies are for these injectors. Moreover, they are double than the recommended latencies from a few threads I have found for Evos.
My cc/min is a bit higher than other people have used for these injectors but not by a large margin.
Anyone else experienced this with a car they have tuned?
I HAVE FIXED THIS ISSUE, SEE PAGE 2 FOR HOW TO FIX IT IF YOU ARE EXPERIENCING THIS PROBLEM.
