1 - 5 of 5 Posts
Those look like modified Bosch injectors. Probably de-capped lower rated injectors which I would not trust if you're trying to make enough HP that you need 2000cc.
I got a set of "1000cc Bosch injectors. Still had the part number, which when I looked them up, they were 550cc injectors that had been modified and the flow sheet that came with them showed about 780cc average.
What is the rest of the part number before the ground off section?
They look like Bosch 0280158821 injectors.
Which are commonly listed as 2000cc or 2200cc injectors
The reason the original seller ground off that part number is likely because they're supposed to be used with CNG only.
1 - 5 of 5 Posts
