1 - 20 of 20 Posts
I'm running the old DW 1000cc injectors and E85 with a protune. One of the injectors will not seat correctly into the manifold. I'm throwing a P0171 code likely due to this. Any ideas on why this injector wont seat correctly and keeps popping out? I've attached a picture of one of the injectors that seats correctly and a picture of the one that is popped out.
The fuel rail is not bent as the stock injectors seat fine and this one particular injector continues to pop no matter where I place it.
When i installed my injectors I also had a really tuff time seating two of them. Best bet is check for corrosion, clean and try again to get it seated. Becareful not to rip a o ring.
My guess was going to be the old o-ring, but you already checked for that. Maybe a little extra loving lube to guide it along.
Discussion Starter #16
I think I found the problem! The top of the injector is missing a small plastic washer see the attached pic... any ideas on where I could get another one or something similar?
Discussion Starter #18
If I can find anything its gonna be a pain in the ass. Its plastic and has a perfect fit so its gonna be a biotch to get on and to have size right
[E-Tuner]
get a friend to bring you to a hardware store, and bring the bad injector and a good one so you can verify the sizes
1 - 20 of 20 Posts
