1 - 18 of 18 Posts
I am upgrading to a 1000CC injector or higher to suit my 600WHP that I plan on building....Anyone know of any good injectors that are a little less quite than the stock and that have a good reputation?
Fic /id
93 Octane with garret 3706R Turbo, Plue 3.5 MAF Adapter and ETS Intake, 4.0 Intercooler, ETS Turbo Back Exhaust with high Flow Cat...And other stuff..Displacment 2.2Stroke 86mmCompression Ratio 9.5:1 street
Here are some of my parts
PartsManley Stroker Forged PistonsManley 4B11 Turbo Tuff I beam RodsBearing Set Main Performance bearingsBearing Rod set Performance bearings Bearing set ThrustARP Main StudsARP Head StudsManley 94mm Stroker crankInspect, Mic and Polish OEM Crank
Garret GT3076R
Competition Cylinder head workCylinder Head SPEC-SSPTUNING Competition GC 2.0T Cylinder Head Spec-SSPTuning Port and Polished Head w/Competition Valve Job (3 angle intake, radius exhaust) SS Intake Valve 35 (+1mm oversized) x 5.48 x 101.85 mm/ EV8/Blk.Nitride/ Undercut/ Back cut/Dish (set of 8) Inconel Exhaust Valves 30.50 (+1mm oversized) x 5.46 x 101.20 mm/Inconel/Dish (set of 8)Supertech Manganese Bronze Intake Valve Guides Exhaust 5.46mm stem (set of 16)Supertech Manganese Bronze Exhaust Valve Guides Exhaust 5.46mm stem (set of 16)Supertech Polyacrylic Intake Valve Stem Seal 5.5mm stem (set of 8)Supertech Viton Exhaust Valve Stem Seal 5.5mm stem (set of 8)Supertech Dual Valve Spring/Ti Retainer/Seat kit 81 [email protected] 34mm (set of 16)Set Valve Lash Clearance (Customer must supply Camshaft to be used with cylinder head)Compression Ratio 9.5:1 street
Yea, you wont see 600WHP also because you would need to upgrade engine internals and your fuel pump.
Maybe with E85 you could see 500WHP, but to reach the 600HP mark, it will take a lot, and cost a lot, probably not worth it. All depends on your goals and income though. 400-500 WHP is the sweet spot for a daily driver IMO.
I have dw 850's(they are louder than stock all aftermarket injectors will be), and I just had to build my motor, so I plan on upgrading to FIC 1000's and upgrading my fuel pump and am hoping to pull maybe an extra 25-50 WHP when I get retuned. Sure would be nice, atleast Ill feel like got something out of all the money I just spent...
Discussion Starter · #15 ·
Well now that I found out my noise is not injectors I don't care about the injector noise..I know I will be getting 1000CC or higher injectors...Seems like my valves are the ones making that ticking noise near the manifold....Anyone have upgraded valves running on there Evo? I cannot figure out which valve company to go with...
So you dont want to spend 8k to upgrade internals, but yet want to run 600whp or "whatever i can" on 1000cc injectors?? Well news for you is that your bill is going to be a shit ton because you'll most likely blow your motor.. Dont be stupid.. slap on a fp red with supporting mods, stay around 380tq and call it a day.. thats roughly 440awhp.
Discussion Starter · #18 · (Edited)
Cool thanks for the input on the fp red I was thinking on running a GT35R ball bearing turbo that should be ok with stock pistons...but I am going to upgrade the springs, retainers, valves and cams;...Which is better FP Red/Black or the GT35R?
1 - 18 of 18 Posts
