wish i would of known that before doing it. looks like ill be putting them back on tomorrow.This has been hashed over a few times. General consensus, especially due to that Mitsubishi aero PDF that floats around, is that removing them is detrimental in the long run. They direct air to the intercooler and radiator and whatnot so it's not a good idea to pull them off. If you want to bling it up but CF ones.
Taking those out does not send more air to the cooler... Look at the air flow diagrams, they are there to increase both airflow through the intercooler and to the brakes. Without they are hitting a brick wall.if u take those plastic pieces out, u can see most of the air are going to the side for oil cooling not much for intercooler if u have those on, i removed my foglight and use rexpeed air duct ,so i assume that i have enough air for oil cooling from the air duct.so i took those plastic pieces out.
Yeah, he needs to at least publish his theories in .pdf format to earn any credibilityTaking those out does not send more air to the cooler... Look at the air flow diagrams, they are there to increase both airflow through the intercooler and to the brakes. Without they are hitting a brick wall.
Please don't suggest something that isn't worth it's weight in camel shit. Those parts are there for a reason, can you tell driving to get some Ramen noodles at Piggly Wiggly, most likely not.
No PDF needed, the photo says enough!Yeah, he needs to at least publish his theories in .pdf format to earn any credibility
Before ever seeing the pdfs a long, long time ago, I always recommended ricers keep that plastic shit on there, stop trying to show off an intercooler, just on sheer principle.
Now would a brake ducting kit rob air flow and/or cause turbulence resulting in lowered air velocity through the oil cooler?
You basically hack up these plastic guides we're referring to and throw ducts in there...
Oh yeah, duh. :duh:No PDF needed, the photo says enough!
Putting in a AMS style brake duct in that location is not detrimental to flow to the intercooler or the oil cooler. It retains the plastic air guides so most of the air is going to be directed to the intercooler. The rest goes straight into the NACA duct and to the brakes via the hoses and the aluminum guides to the center of the rotor.Now would a brake ducting kit rob air flow and/or cause turbulence resulting in lowered air velocity through the oil cooler?
The air guides work for the oil cooler as well.
