1 - 20 of 21 Posts
Hi all. I think I have to finally give up on my Evo X, but really don't want to, so any pointers or advice to what might be causing problems would be seriously appreciated.
To give you a quick lo down. I got my 2008 GSR Evo X on the 20th of October last year from a Japanese car auction (Yes I live in Japan). The car is heavily modded and done a little under 70k miles. The mods are clearly extensive, but I don't know all the details, besides cosmetic, shocks, exhaust, cam, and having the ECU worked on.
I promptly drove the car back from the auction without noticing too many problems, seemed a bit sketchy in automatic, but shifts etc were fine in manual and I didn't see any issue with power or obvious problems. Basically after driving back for 4 or 5 hours or so on various roads and motorways my conclusion was that it just needed dialing in, mapping and some ecu work, I certainly wasn't too worried. Anyway in less than a week of having the car back I went down to the local supermarket and when I cam out the car was dead.
It was almost as if the battery was dead. After trying myself to get it started I gave up and called a local garage I use for basic routine maintenance. They tried to jump start etc, but in the end gave up and took it back to the garage. After a while they concluded the the car was basically F**ked and gave up on it. I spoke with some mates who know a lot more about cars than I do and they said they would be very surprised if the problems were that major without any prior symptoms (my thoughts exactly). Something was clearly a miss, but as the local garage is a bit of a small Micky Mouse operation I decided to send it to Mitsubishi.
The Car is now still at Mitsubishi, and it seems they clearly can't fix the problem either. It's been over 6 months now and I'm at the end of my tether. The conclusion from the first garage was the as the engine wasn't holding compression, it was broke, and therefor they were done with it. It seemed they jumped to this conclusion without first trying some basic fixes. I'm also a little worried that these guys may have done more damage than good. They said they reset the ECU and clearly tinkered with other stuff. After a while at Mitsubishi the conclusion was that the ECU was broke (somewhat logical), so I forked out for a new ECU, but still no fix. They said after changing the ECU it was trying to start, but basically still wasn't firing. Starter motor my first thought?
I've got my second kid due to be born at the end of June and am up to my neck in it with work, so as much as I'd like to get my car fixed and drive it, it's also come to the point where I feel like the Mitsubishi guys aren't going to be able to fix it, and after over six months I should cut my losses and just sell it.
Sorry for the long ramble. Any help would be really genuinely appreciated.
Odds are if the car is heavily modified you have larger injectors and would immediately end up with a no-start condition with an ECU reflash to stock as well as with the new ECU.
Your only option here is to get the car to a shop that can go through the mods, set up a new tune, and go from there. You'll want a tuner shop and not a repair shop.
Doesnt sound like a starter issue. More like ignition.
As mentioned above, you're likely wasting your time at mitsu.
Where do you live in Japan, there are tons of reputable tuning shops, but ideally try and found out where the car was built.
Failing that, find a tuner that builds evos and have them start from scratch.
Discussion Starter #4
Sorry for the late response, babies sometimes come earlier than expected!
Thanks for the input. It's on it's way to a recommended tuner in Nagano (biggest city near me).
I'm going to try and speak with those guys and give the the low down first.
Any other thoughts?
Cheers
How long did it take you to drive to the supermarket? Was the engine warmed up or was it still cold?
How long were you inside before you came out and tried to start it?
These cars have a huge issue with running extremely rich until the engine is warmed up, and if you shut it off before it's warmed up you run the risk of the cylinders being flooded with gas and a really hard time getting it to start back up.
Discussion Starter #7
Only a 10 minute drive there, and I couldn't have been inside much more than 10 minutes. I'd have thought the guys who had looked at it would have picked that up?
Discussion Starter #9
So the shop got back - They're called "Boss" based in Nagano city. The web site is ap-boss Basically they said best case scenario would be ¥500,000 and worst case ¥1,000,000. They believe they need to start tearing down the engine to find the problem, so essentially they are going to rebuild the engine, and based on the fault it'll cost X, the lower estimate is for a standard rebuild.
They based their assumptions on the cell motor not moving, i.e they can't move it by hand, which they should be able to apparently. I have no idea on this. But at this stage I don't want to drop that kind of money on it, so am thinking I'll get it back and sell it as is, which really sucks!
I'm still not convinced it isn't something more simple, but they seem to make a sound argument for it not being electrical.
The only problem with the car now is there is no idea of what has been done. So Mitsu replaced the ECU? If the car has extensive mods, it probably has bigger injectors and a stock MAP won't mix with that. So now there is really no idea of what all needs to be done. It needs a new tune for the mods, but no one knows the mods. It could potentially have an issue with the motor. Does it get fuel or anything? There isn't some kind of security system installed right?
Unfortunately, there so many variables, I think the only option is for the tuner to open everything up, see what injectors the car has, what cams, etc.. figure out what the issue is and the try to get it going. But it's not cheap unfortunately. It would help alot if you could find the original owner or shop.
Discussion Starter #15
Agreed. I had tried extensively to find the previous owner/s and shop/s with no luck. I don't think it has after market security. It would definitely a tune, but I believe it should start on the factory ecu and run with the mods. At the minute it can't even be started.
Discussion Starter #16
Got her back today. Will have a little investigation, but will aim to have her sold within the next few weeks *sigh
That sucks.
But the car may very well have bigger injectors, cams, boost controller, etc.. Even without knowing any other mods, just with those, the car won't start and if it did, run terribly since it's not tuned for them anymore. Mitsubishi replacing the ECU and flashing to stock really did not help your chances of getting it running.
Discussion Starter #18
That sucks.
As Mitsu couldn't start it they put back in the old ECU, but no idea what state thats in. If I could get it started then it could go straight for a tune, but without getting it started and not knowing the problems I don't want to drop the kind of money I'd be looking at on it to rebuild the engine.
1 - 20 of 21 Posts
