I'm reinstalling the baffles onto the Valve Cover and I am getting mixed advice from the internet. Is RTV sealant necessary for reinstallation of the baffles onto the Valve Cover? Or can I get away without adding any? Thanks in advance.
Yes, I used cap head screws with lock washers and red loctite.How are you planning to install the baffles? Will you be using loctite with lock washers and bolts?
Nothing specific just hand tighten. They can't be cranked down super tight or the threads will just strip out.Did you use any specific torque specs?
