1 - 2 of 2 Posts
2008 GSR
New to evo's so pardon the ignorance, but is this normal? Note: no fluids have been drained.. With the trans on the ground, if you tilt it bell housing side down it pours fluid out the center section of the intermediate shaft, where the diff would bolt up, but not from the other opened side when tilted the other way. Is there a bad seal somewhere? Is it trans or diff fluid? Also, the diff is out and pouring fluid from both axle inputs. I assumed it was a sealed system so I must be missing something here. Any help is appreciated
Automotive tire Wheel Motor vehicle Crankset Bicycle part
The evo x is not a sealed transmssion. It gets its seals from numerous things, including the O-rings on the transfer case, and the driver side CV axle.
What you are experiencing is normal, do not be concerned.
1 - 2 of 2 Posts
