1 - 20 of 59 Posts
I finally got my red last month yay!
Goal for this car is to have a 400whp plus and to put this fat b**ch into diet!
This is the list to get to support the red turbo
Supporting Mods:
-AMS Widemouth DP
-Speed Circuit TP
-AEM Wideband UEGO
-DW injectors 1000cc
-Kelford bs w/ Springs
-Drop in piston and Rods
-Spec 3 Clutch
- Upgraded WGA Blouch or Forge
I'm I missing anything? If I am please comment and I would like the opinion of others that have this turbo as well thanks for viewing.
What drops in pistons and rods are you going with and any reason why? lots of guys here run this set up with stock block?
Discussion Starter · #7 ·
Fuel Pump
I would go with a Twin Disc instead of a Spec Stage 3
Change Kelford to GSC Stage 2
Again just all my opinion.
I see that is some good selection of parts although I see most guys running kelfords and cossie with springs. As far as twin disk such as Exedy I heard it put alot of strain in the Clutch master cylinder thus snapping it in half. Spec 3 looks good for the price and I see people like hollywood using it although I might change that whenever I get more cash.
Yes... but it depends on what you have right now. If you have a 3" intake that just has a step down coupler between the last pipe and your turbo, you just need a 3" straight coupler.
Discussion Starter · #15 ·
Yes I would. You will easily out flow the stock one.
Get the Speed Circuit one and have them send a 3" coupler instead of the Tapered one. :)
Ok, I see thanks for the help man I just ordered a speed circuit test pipe and that might be the next order for next month. Right now I'm in the process of buying all the supporting mods for the FP red.
Discussion Starter · #17 ·
I got about 17000 miles on the engine and yes I'll be running pump gas. I'm looking at 400+ 25psi or below w/ cams.I've read some owner with bent rods or pistons with holes in them I just thought that it would help to start freash. I guess I'm just paranoid and wanted to make sure the engine is good to go, but I think I'll just leave it as it for now till I get the money to build the engine.
^^ Why not go above 8K with cams and springs? Is it because he's gonna keep the stock rods/internals for now?
1 - 20 of 59 Posts
