New product just in! Motul DCTF SST Transmission Fluid! We have these in stock and ready to go.
8L required for the MR SST Transmission.
$130 shipped (8 bottles) anywhere in the US! It doesn't get any better then this!
Need the transmission filter too? No problem! We got you covered. $150 including shipping with the purchase of the oil from us.
Need to know how to drain the oil? Here you go:
"Once you remove the undertray, there are 3 allen head drain plugs on the underside of the transmission. Unscrew them and let the oil drain. One of the plugs will take a lot longer to drain than the other two. Once all the oil has drained, replace the 3 plugs and torque to 18ft/lbs.
You will then need to remove the airbox to get to the SST fill port. Once you remove the airbox, youll see another allen head plug on top of the transmission. Remove this and use a funnel, the stock SST can take 8 litres of SSTF oil. If you have the SSP deep pan you will need to add 4 more litres for a total of 12. Afterwards replace the fill plug and tighten to 18ft/lbs.
Then replace the airbox, start the engine and let it idle for a couple minutes. Move the shift lever to every position, then return to P or N and your done!
Also, the allen headed plugs are all black colored, you cant miss them.
If you want to replace the SST filter, it is located outside the transmission on the drivers side. Its a small black plastic canister with a large hex head, I cant remember what socket size fits on there. The filter sits inside this canister. Unscrew this and immediately replace with the new one, youll lose some oil when you remove the filter cap. "
