1 - 20 of 22 Posts
I was doing a boost leak test in my 08 GSR. I have found a tiny leak at the AEM Fuel Pressure Regulator nut (the one used to adjust pressure). The aem regulator cames with my MAP AFPR kit I have installed recently. Is such leak expected? Could be a damaged regulator?
We have made the test with up to 26psi.
Thank you,
Ziki
Sub'd
Will such design flaw (considering that link info is correct) cause fuel pressure fluctuation? I had tuned my GSR for 11.5-11.3 AFR in my city (350m high), then a few days later, I have raced at sea level, which was giving me 10.6-11.0 AFR.
If this a design fault, wouldnt we have heard more about it in this forum?
Btw, I have FIC 1100, Walbro Intank (UR Pump kit), AMS Fuel Rail, K27 Anti-Surge-Kit.
more likely that the race heated up the engine and caused it to run richer.
the leak whilst annoying, wouldn't change the AFR's that much...
mine is leaking as well... i guess once I get that HEXSEAL nut to fix it, then i can see if anything changed :)
Discussion Starter · #8 ·
it better be the right size, ive ordered 5 of the damn things...
Discussion Starter · #11 ·
Let me know once you get them
any idea of the right part number?
No, I willhave to take off the lock nut on top of theafpr and bring to get measured in order to find the right part #.
I won't have time until next week so if anyone else finds it let us know !
damn.. they dont fit.
i put a set of verniers on the thread, its 4.8mm... just looking at the apx site now to work out what size I need, but its not immediatley obvious..
will post up when i have a working solution..
maybe AEM changed the design, anyone want to go sign upto their forums and put a post in that thread saying they dont work?
Discussion Starter · #17 ·
Received mine. They are too small. US$100+ thrown in the trash :(
ok I think its 10-32, i measured the pitch of the thread and there seemed to be slightly more than 1 per millimetre.
so 32 threads per inch seems about right.
so did you try this size ? does it fit?
thanks!
1 - 20 of 22 Posts
