21 - 22 of 22 Posts
Discussion Starter · #21 ·
I will try to find it locally. It takes too long and cost too much to import such nuts.
I was doing a boost leak test in my 08 GSR. I have found a tiny leak at the AEM Fuel Pressure Regulator nut (the one used to adjust pressure). The aem regulator cames with my MAP AFPR kit I have installed recently. Is such leak expected? Could be a damaged regulator?
We have made the test with up to 26psi.
Thank you,
Ziki
what was done for this because I’m having the same problem right now on my evo x with the adjuster on the aem fpr
21 - 22 of 22 Posts
