My base pressure (Under Vacuum) is 43psi with the stock FPR. As of now I ditched the BlaqOps progressive controller because for some reason it decided it was union and would take breaks 5 times a day for nearly an hour each time. Now I have 2 stock pumps connected to a Y fitting and one comes on with a Hobb's switch at 5 psi. It actually works quite well, no spikes of too rich fueling.
Your issue sounds like you are either;
A) Over running the FPR (Which I kind of doubt)
B) You have a leak in the tank thats releasing pressure (Most likely)
