So my son's new car, 08.... is starting to piss me off. We have gone over and over this thing end to end...can not figure out why the AFR is going nuts.
Time line and things we have had to change so far..
All in all my gut and butt feeling is that the car is back on track, and either the wide band is on crack, or the gauge is bad. But knowing what can happen if it really is running lean, I have to get to the bottom of it.
I see a ton of topics on line that are "similar" to what we are seeing, but in the end they seem to be a result of one of the things we have already replaced.
Any guidance is greatly appreciated.
- Bought car from Arizona (we live in northern Colorado), drove home 13 hours straight. Car ran BEAUTIFULLY the whole time.
- Car started missing, running like crap after about a week, major hesitation when you rev.
- New NGK plugs, and bigger gap - old ones were heavily carboned/black
- New tune by Apexpowered / Marc - removed the E85 tune for now, and improved the 91pump tune by about 100hp on the dyno.
- Ran perfectly for THE DAY...limp mode on way home.
- Barely idles, sputters, gotta hold it to the floor to start it.
- AFR all over the charts.
- New MAF
- Re-gapped plugs with wider gap
- Hooked mighty vac to multiple ports in the engine bay. 100% held vacuum in all cases. (Doesn't mean I didn't miss some connection some where...but confidence is high.)
- New FIC injectors - my fault, ran bad test and fried two. Spendy lesson!
- Cleaned and tested the O2 sensor, it passes test - brake clean method
- New battery
- Car starts much easier, has big cam, so to say it idles smooth is generous...but idles properly.
- I can't recall the S & L trim numbers, but they seemed good.
- Scanner shows O2 only reads/registers when you give it gas.
