1 - 20 of 21 Posts
I bought my Evo X in September of 2018 and looking to make more power into it. I learned a couple things but I’m still new to it. I will have roughly $4,000 to $4,500 budget to get it as far as I can. I was looking to see what y’all recommend? I’ve already added a cold air intake and previous owner put on a bov. I’d appreciate all the help I can get bros
You could probably go as far as full bolt ons, an ATP turbo kit, and tuning with that budget man
I would recommend you look into just getting a full exhaust and a electronic boost controller. On 91 that should net you around 340ish whp, little more on 93. If budget still allows do injectors, fuel pump and go e85 for 400ish whp.
For each mod that changes the airflow you need to get tuned or risk HUGE problems!
Always better off doing everything at once.
You have a few options.
Buy all the Bolton’s, install them and drive like a grandma without boosting to a reputable tuner. Or do a remote tune? Or
Drop off your car and let the tuner do everything.
Do you have a tune? Find a good tuner first and get a tune. Get a wideband and boost gauge. Find out what type of software the tuner supports. Cobb AP is decent for minor bolt-ons. If you ever plan on going past bolt-ons later you are better off with Open Source. It all depends on your goals not that those goals won't change over time but, try to set a realistic goal within your budget. Save up extra funds cause things can come up. Good luck with your build.
4500, if spent carefully, could yield a FBO+MHI 18k+E85 & tune.
There are some things you can leave out if you so choose. An intake at that power level isn't a necessity. A drop in filter like the cosworth would be more than fine for what you want.
Search the used market unless you really want new for everything.
Intake, Downpipe, Exhaust Manifold, 3 port boost solenoid, Injectors, Pump, Flex Fuel Kit, AFR/Boost gauge and tune.
I made this list awhile back for people asking me where to start to make 500+:
Semi Budget 500-600whp evo x (On E85)
- TPC Turbo R Spec or G Spec or GT Spec $1600-$1700
- MAP Cast Manifold $500
- WTF 500 WHP (E85) Fuel System $1275
- WTF Flex Fuel Sensor $400 *optional for flex
- MAP 3” Intake $275 (or 3.5” for over 520whp)
- Depo Racing Downpipe $190
- Depo Racing Test Pipe $100
- Depo Racing 3.5” Intercooler $250
- Depo Racing UICP $150
- Any cheap Cat Back $200-500
- EBCS $100
- Wideband $200
- Crushed OEM BPV (Or Tial QRJ)
- DF or Radium Catch Can $300
- Tune $300-500
Approx $5000-6000
- EBCS $100
- Wideband $200
- Tune $300-500
Approx $5000-6000
MAP Cast Manifold has jumped in price. $649 uncoated and coated is $749 now.
Let me know which direction you went with your Evo and what kind of numbers you put down. I've got my Evo X over at kozmic right now having the engine built and I've taken similar mods so I'm hoping for around 450 to 500 whp on the Garrett 3576R. Always exciting to see a building progress.
Discussion Starter #15
No current tune, due to me being away for two months. And looking to drop my car off at English Racing in Portland to get tuned. Appreciate that advice dude ??
I’d highly recommend an e-tuner rather than English Racing if you don’t want to be underwhelmed. Chet Rickerman, Christian Muna, both people I’ve interacted with and provide pretty affordable e-tuning, and who both know how to squeeze more power than ER. ER feels like an OTS tune more often than not. I know they once made barely 500 on a 6466 lmao.
Are you talking about Devin's 6466 car? The one that blew up when he went to another tuner lol. He's on pump gas too, only wanna push it so far.
Idk. I’m running 440whp on pump in the same area as devin on a MHI 18k. 510 e85. There are plenty of pump gas 6466 Evo X’s pushing over 500 safely. His car “blew” because of valve damage because he was using 2-step every second he could. I also have had very bad experiences with English Racing working on my head then it mysteriously dropping a valve. You can ask for their rep around other tuners and they’ll tell you they’re a very shady bunch. Just be careful.
Discussion Starter #19
Damn I would’ve thought that they were good considering hearing people talking about them. But appreciate the help and advice fellas I’ll do a search on some credible tuners
Agreed, when I was shopping around my local circle for pointers Chet came up repeatedly as the person to go with.
1 - 20 of 21 Posts
