1 - 8 of 8 Posts
Wanting to go lower with the eibach pro kit springs. But going lower on those, do i risk blowing a shock? or will they be fine. No racing, no auto xing.
you will be fine...have had these on for 13K mi with no problems...you will need to get a roll center kit (whiteline) since these springs are quite low and you will definitely feel an improvement with the rck...GL!
aka FooFighting24/7
also rockin h&r, which has one of the biggest drops from stock for springs alone, no problems.
also put up a how-to incase you need direction if you DiY
What does the center roll kit do? and I won't rub will i, stock wheels. Newbb
im rocking eibach and rck no problem at all - our car should have come with this stock
1 - 8 of 8 Posts
