LOL my rubber lip ripped off before I even lowered my car.any suggestions to whats a good lowering spring that i can install without ripping my front lip and side skirts off in the snow and bumps? cars sits somewhat low now cuz of the kits.
How did you manage to do that?LOL my rubber lip ripped off before I even lowered my car.
Hauling too much ass clearlyHow did you manage to do that?
The front aero lip is already low at stock ride height. Mix that in with some steep curb ramps and you find out quickly how low it is. Didn't take more than a couple of scrapes to pop the plastic tabs that hold it in place and once they go it starts flapping around ripping the rest off.How did you manage to do that?
I had 5-6" of clearance with the front lip - that was ALOT considering i I'm now 3" off the ground and can still drive through blizzards without issue. Take off that rubber lip and gain an inch of clearance. Ditch the plastic under tray, I'm willing to bet you will lose it within a year anyways.The front aero lip is already low at stock ride height. Mix that in with some steep curb ramps and you find out quickly how low it is. Didn't take more than a couple of scrapes to pop the plastic tabs that hold it in place and once they go it starts flapping around ripping the rest off.
My front lip is 3.75" off of the ground, I regularly hit and drag cones with it, scrap on driveways and off-camber roads. I haven't had a single issue in almost 4 years with it coming loose, just lucky I guess?The front aero lip is already low at stock ride height. Mix that in with some steep curb ramps and you find out quickly how low it is. Didn't take more than a couple of scrapes to pop the plastic tabs that hold it in place and once they go it starts flapping around ripping the rest off.
As much of a PIA the undertray is, I wouldn't remove it. All you need is a stick, debris, etc getting into your serpentine belt, not to mention the aero loss under the car and the loss of cooling for the tranny.I had 5-6" of clearance with the front lip - that was ALOT considering i I'm now 3" off the ground and can still drive through blizzards without issue. Take off that rubber lip and gain an inch of clearance. Ditch the plastic under tray, I'm willing to bet you will lose it within a year anyways.
