I will go ahead and actually answer your question...Eibach pro kit will be too low for the snow...the springs lower GSRs 1.2"/1.0" F/R and on the MR (same springs) 1.6"/1.0"...In reality though my GSR appears to be closer to 1.5" lower up front which is quite low for DD especially with snow. You will scrape a lot and might end up being a snow plow. I would recommend some springs that don't go as low especially with snowy conditions...Recommendations are Works .9 or .5" springs or Muerellized springs (~.75")...but if you really want that somewhat slammed look than go for the Eibachs...the Eibachs come standard on the FQ 400 and are a nice springs and definitely reduce body roll and improve handling but they do not take bumps and uneven road as well as the stock suspension. Also, if you do get the Eibach springs you need to get the roll center kit by Whiteline...drove on these springs with and without the roll center kit and there was a very noticable improvement with the kit, so it is a must and is recommended for any lowering springs that lower the car over 1 inch...GL!
