1 - 20 of 88 Posts
I will add more as time goes on and if some of you have different calibrations let me know and I'll add here as well.
Cobb AP;
AGP 3" CAI
SpeedCircuit 2.5"->3" CAI
Primo 3.5" (Can also be used for MAPerformance 3.5")
AMS 3.5"
nice.
now post ECUFlash friendly versions :)
ie column of data, and in raw scaling :D
if you can be bothered that is :)
my ecuflash is set up in rows, and in g/s
Win :)
D i can send you a rom so you've got the numbers with your clever-person scaling that i have entered using normal person scaling...
nice.
Within excel there is an option to take row data and make column data. Here is how:
1) Highlight just the data that Hollywood has posted. Not the entire row, but the data.
2) Copy the data, either ctrl+c or copy button
3) Click cell A4, that is where we are going to paste the data
4) Right click on cell A4
5) Click "Paste Special"
6) A dialog box opens, click the box for "Transpose"
7) Click ok, and your data should now be in column format
**Excel won't let you paste this in any of the area that is copied, you must select else where on your spreadsheet. That is why I selected A4.
No clue what the raw scaling means.
I'll try and get calvin to give me the scaling for the ETS 3.5" when I get it together and tuned.
yea should be different, as the ETS uses a maf adapter and velocity stack on the filter. So I think the setup would be a bit different. I'll find out
[E-Tuner]
1 - 20 of 88 Posts
