Attached is a new updated Cobb ATR log, can you make it work with it? I keep getting errors trying to load it.
Thanks for the log. I updated the script and it is now working with this log.
Have I told you how much I love you lately? :thumbup::thumbup:Thanks for the log. I updated the script and it is now working with this log.
I can't get this to work. Is there some sort of nomenclature/whatever missing?
I tried the original heading's that come standard with EvoScan, no dice. So then I tried renaming to the exact column titles listed....still nada. Tried 2 different browsers....didn't make a difference. Tried smaller files (half the size), and still nothing.:wtfsign:
"X" is the relabeled headings
OK I went out and logged just the 3 parameters.
Question: by staying out of boost (to accruately reflect the amount of air flowing w/o compression) I'm limiting my voltage range. This kinda caps the 'Multiplier Values' to a MAF Voltage to ~3 (a bit less for me). Rather than going and changing my boost tables, could I just drive normal to get to higher speeds (i.e. boosting onto the freeway) and simply do a 'Sort' to delete any lines w/ positive boost values? Will this have any sort of unwanted effect on the logic of your program?
For instance, I can cruise at 80 and stay out of boost (allowing me to log the higher MAF voltage ranges) but I'm going to boost quite a bit to get there![]()
You don't need quotes (")I love you for making this.
But, It dont work for me! :computermad:
I tried every variation and even deleted all the shiz except "MAF Voltage,CurrentLTFT,STFT".
I just double checked it and there aren't any quotations around them.You don't need quotes (")
Remove them from the headers and it'll work.
Remove current and add Used after LTFT;I just double checked it and there aren't any quotations around them.
Log Type: AccessTunerRace #2
35 maf ranges found.
MAF Table Multiplier -
MAF Voltage 1.29 1.33 1.37 1.41 1.45 1.49 1.52 1.56 1.60 1.64 1.68 1.72 1.76 1.80 1.84 1.88 1.92 1.96 1.99 2.03 2.07 2.11 2.15 2.19 2.23 2.27 2.31 2.35 2.39 2.42 2.46 2.50 2.54 2.58 2.62
Multiplier 1.021 0.959 0.990 1.041 1.043 1.035 1.016 0.995 1.006 1.008 1.004 1.050 1.028 0.985 0.999 1.014 1.022 1.018 1.011 1.009 1.012 1.017 1.021 1.021 1.019 1.028 1.033 1.034 1.027 1.024 1.027 1.022 1.020 1.022 1.015
Trim Multiplier for MAF Voltage 2.66 to 5.00 --------------------------------------> 1.017
PHP:Log Type: AccessTunerRace #2 35 maf ranges found. MAF Table Multiplier - MAF Voltage 1.29 1.33 1.37 1.41 1.45 1.49 1.52 1.56 1.60 1.64 1.68 1.72 1.76 1.80 1.84 1.88 1.92 1.96 1.99 2.03 2.07 2.11 2.15 2.19 2.23 2.27 2.31 2.35 2.39 2.42 2.46 2.50 2.54 2.58 2.62 Multiplier 1.021 0.959 0.990 1.041 1.043 1.035 1.016 0.995 1.006 1.008 1.004 1.050 1.028 0.985 0.999 1.014 1.022 1.018 1.011 1.009 1.012 1.017 1.021 1.021 1.019 1.028 1.033 1.034 1.027 1.024 1.027 1.022 1.020 1.022 1.015 Trim Multiplier for MAF Voltage 2.66 to 5.00 --------------------------------------> 1.017
Yep I took that from your log, I've attached the modified version.Is that from my log? ^^^
I just tried what you said and tried every other variation he gives on the site and none of them worked, I just kept getting that field setting error.![]()
THANK YOU! :bowlol:Yep I took that from your log, I've attached the modified version.
