Is it worth it?
Oi! Thanks for the warning Mike. Would you say they aren't worth the trouble then?Wes, just becareful with the aluminum ones. If you thread those wrong, they can strip.
An aluminum magnetic drain plug?? That's wrong on so many levels. ha haWes, just becareful with the aluminum ones. If you thread those wrong, they can strip.
I have one but have not installed it yet. Note that I know of at least one person that had the valve accidentally open on them so I wouldn't recommend one without using an optional spring clip to prevent accidental opening.Sort of off topic, but has anyone tried those oil drain valves? Its a valve that replaced the drain plug, and you can open close it with a wrench.
Sort of like this one: http://www.fumotousa.com/faq.htm
