Check Fred Beans Parts. I remember seeing it on their website.
You know what? Im a noob. The upgrade kit is the plate. You need the CNC and the kits.Check Fred Beans Parts. I remember seeing it on their website.
Thanks man I might have to. What do you have to cut?I HAVE DONE THIS CONVERSION.......it is not fun. you will need a dremel with cutting discs or grinding tip or small angle grinder. your also going to need to bleed your brakes and clutch. this would be a good time to remove clutch restrictor pill since you have to install new SS clutch line. if you have any questions i'll help you.
What was the reasoning? I trust shep, just curious.FYI, Shep says leave the restrictor pill in.
heres a great how toFYI, Shep says leave the restrictor pill in.
Funny, Carbonetic says take it out.FYI, Shep says leave the restrictor pill in.
Mine survived for 7k miles with an Exedy Stage 2 clutch. Just be prepared for it to break, shouldn't be immediately, but when it does you're gonna have to wait for shipping on parts and blah blah before it's drive-able.What is the typical life of the stock CMC? I know the thing is made of plastic and am wondering if since I am upgrading the clutch to ACT HDSS clutch if I should go ahead and get the Magnus upgrade. I just shelled out some cash for the flywheel, fluids, and clutch so am hoping I can get by till next month.
That's what happened to me after 5k milesMine survived for 7k miles with an Exedy Stage 2 clutch. Just be prepared for it to break, shouldn't be immediately, but when it does you're gonna have to wait for shipping on parts and blah blah before it's drive-able.
And might have to pay for this depending on where it happens (yes, that's from my CMC failing):
seems like to me i read about everyone with around 3k miles on an after market clutch having the stock CMC fail on themWhat is the typical life of the stock CMC? I know the thing is made of plastic and am wondering if since I am upgrading the clutch to ACT HDSS clutch if I should go ahead and get the Magnus upgrade. I just shelled out some cash for the flywheel, fluids, and clutch so am hoping I can get by till next month.
