Status
Not open for further replies.
1 - 16 of 16 Posts
Vendor
MAP Mitsubishi Ralliart to EVO X Turbo Swap Kit
Mitsubishi Ralliart to EVO X turbo swap kit. This kit is designed for Ralliart owners who want to run a stock frame EVO X turbo. Includes everything except the turbo, inlet pipe, outlet pipe, and manifold.
Includes
* O2 Housing / Turbo Outlet Gasket 1555A289
* 2 Manifold - Turbine Studs MN119784
* Banjo Bolt (Head Side) MF650102
* Banjo Bolt (Turbo Side) MS650013
* 2 Coolant Bolts MF650114
* 2 Water Line Gaskets MF660064
* 2 Turbo Oil Feed Tube Gaskets 1226A003
* 4 Water Line Gaskets MF660065
* Oil Drain Tube to Turbo Gasket MR258477
* Turbo Water Feed Pipe 1310A577
* Turbo Water Return Pipe 1310A469
* Turbo Oil Return Tube 1225A181
* Turbo Oil Feed Tube 1225A155
Our price: $249.99
: Send us a PM|||||
: NateAtMAP|||||
: 1-888-MAPERFORMANCE x 114|||||
: [email protected]
was just looking at this on the site :) ill send u a pm cause i need goodies
Any way to get a deal with this and your Short runner manifold and EF2/3? I plan on doing the X swap when i return from deployment and don't want to be limited with the stock evo turbo. I love the EF2/3's ability over the stocker too much.
Vendor
Discussion Starter · #11 ·
Big brake kit options exist, my friend! It all depends on what your budget is for brakes...shoot me a PM when you are ready and we will see what we can scrounge up for you!
anyone who does buy this should still definitely refer to the in-depth list on evom of all the parts needed.
this kit is awesome and when i get the funds for the swap ill for sure be hitting you guys up :D
1 - 16 of 16 Posts
Status
