1 - 6 of 6 Posts
· Vendor
The Eibach ANTI-ROLL-KIT reduces body roll through increased design stiffness over stock Sway Bars. The result: increased handling and cornering grip in any performance-driving situation.
Manufactured from cold-formed, high-strength aircraft-grade steel for precision performance, and finished with a long-lasting red powder coat finsih, the ANTI-ROLL-KIT comes complete with greased urethane bushings for improved responsiveness and all mounting hardware and instructions for easy installation.
Features and benefits:
* Performance Tuned Handling
* Further Reduce Body Roll
* Precision Engineered for PRO-KIT & SPORTLINE Performance Lowering Spring Kits
* Part of the Eibach PRO-PLUS, PRO-SYSTEM-PLUS, SPORT-PLUS & SPORT-SYSTEM-PLUS
* Million-Mile Warranty
Only 2 sets left at the $299.99 Price!
TECHNICAL INFORMATION:
FRONT:
OE bar: 25mm (1.0 in) solid
Eibach bar: 29mm (1.1 in) tubular and
adjustable
OE measured bar rate: 42 N/mm (239 lbs/in)
Eibach measured bar rate: 2 position
adjustable
P1 = 49 N/mm (277 lbs/in)
P2 = 54 N/mm (308 lbs/in)
OE bar weight: 5.4 kg (11.9 lbs)
Eibach bar weight: 5.12 kg (11.3 lbs)
Bushing: New urethane bushings with grease
grooves included
REAR:
OE bar: 23mm (0.9 in) solid
Eibach bar: 25mm (1.0 in) tubular and
adjustable
OE measured bar rate: 61N/mm (350 lbs/in)
Eibach measured bar rate: 3 position
adjustable
P1 = 62 N/mm (359 lbs/in)
P2 = 69 N/mm (398 lbs/in)
P3 = 71 N/mm (407 lbs/in)
OE bar weight: 4.0 kg (8.8 lbs)
Eibach bar weight: 3.9 kg (8.6 lbs)
Bushing: New urethane bushing with grease
grooves included
PM ME to place your order!
: Send us a PM|||||
: NateAtMAP|||||
: 1-888-MAPERFORMANCE x 114|||||
: [email protected]
1 - 6 of 6 Posts
