Status
Not open for further replies.
1 - 20 of 104 Posts
Vendor
MAP AFPR Install Kit with AEM Fuel Pressure Regulator (Evo X)
This kit includes a AEM adjustable fuel pressure regulator, white face Turbosmart fuel pressure gauge, fuel rail adapter, mounting bracket and all necessary fittings to accurately adjust and monitor fuel pressure in your Evo X! Includes black and silver shadow series fittings for a cleaner sleeper look under the hood!
Note: Our push-lock fuel line is black rather than blue for a low cost alternative that still maintains the stealth look!
MAP Air / Oil Separator Kit for Evo X
The MAP Evo X Air & Oil Separator Kits are plumbed into a vehicle's PCV system to capture the excess crankcase vapors and the residual oil mist from reentering the intake track. Evo's from the factory vent these excess crankcase vapors and residual oil right back into the intake manifold which could cause detonation and oil deposits to form in the intake track including the valves. The polished Billet Aluminum body compliments any engine compartment and can be chromed or powder coated for a custom look.
Key features
  • Complete solution - our kit includes everything needed to plumb this into your Evo X
  • Simple bolt in installation
  • Billet mounting clamp to secure AOS tank to fire wall
  • Bottom drain with elbow that makes draining the collected oil virtually mess-free
MAP 600hp Fuel Pump Upgrade Kit w/ DW300 (Mitsubishi Evo X)
*Also available with Walbro 255hp if desired
Introducing the highest flowing in-tank pump yet. Surpassing the competition 300LPH at a time. This pumps fits the same profile as a Walbro GSS342 for a simple drop-in installation.
Click here for more detailed information and testing results.
Also included is the MAP fuel pump installation kit to make installation a breeze! Our CNC machined fuel pump housing designed to replace the factory fuel pump/filter assembly and includes all hardware for a bolt-on installation.
  • Flows 300+ litres per hour
  • In-tank application specific fitment
  • Ethanol compatible
  • 3-year no-fault warranty
  • Quiet and reliable turbine impeller
MAPerformance Phenolic Intake Manifold Spacer / Thermal Barrier
The MAP intake manifold spacer has been re-engineered from a phenolic material to avoid squishing issues that are common in competing products and yield better thermal properties. Please keep in mind that you will be spacing your intake manifold by 3/8″ and some bracketry may need to be modified.
Sealing Options:
Phenolic is a hard material and although it can be and has been used without any type of sealing device in the past we generally recommend either adding two OEM gaskets to your order below (one for each side of the spacer) or you can utilize a sealant (Type 2, copper spray, etc.) to do the job without the use of gaskets.
: Send us a PM|||||
: NateAtMAP|||||
: 1-888-MAPERFORMANCE x 100|||||
: [email protected]
: The MAP blog - Get the inside track on what we're doing!|||||
: Check us out on Facebook|||||
: Follow us on Twitter
Vendor
Discussion Starter #2
MAP Short Runner Tubular Stock Replacement Exhaust Manifold
At MAP our goal is to offer the highest quality products available at a price that anyone can afford. Our new tubular stock replacement exhaust manifold is made of high quality mandrel bent SUS304 stainless steel and electronically tig welded at all joints. Our manifold is designed to retain your factory turbo orientation. The shorter length runners help to increase spool while still allowing for big power gains up top!
MAPerformance Ultimate Duty X-beam Connecting Rods (Evo X)
  • Made from 4340 billet steel for the ultimate strength
  • American made (forged, machined, and finished)
  • Shot peened/stress relieved and heat tempered
  • CNC'd to perfection for the ultimate in fitment
  • Require no modifications to the block or crank to fit
  • Come with 7/16" ARP fasteners as a standard feature, not the weaker 3/8" like everyone else
They are rated for over 300whp per cylinder (1200+whp per motor!).
For those of you wanting the best rod available for your build, look no further than these as there is nothing better to be found!
MAP Stainless Steel Test Pipe (Mitsubishi Evo X)
This MAP test pipe is constructed completely of 304 stainless steel for the utmost durability and includes gaskets and hardware for easy installation. It also features an anti-fouler for the secondary o2 sensor to avoid any check engine lights. Please note this product is intended for off road use only.
: Send us a PM|||||
: NateAtMAP|||||
: [email protected]
Vendor
MAP Single Tip 3" Catback Exhaust System with Varex Muffler (Mitsubishi Evo X)
This full 3" exhaust system features a single 4" diameter tip for a subtle look that exits on the passenger side. It is constructed entirely of 304 stainless steel for ultimate durability. It also features a v-band disconnect for easy installation and removal, and includes all necessary hardware and gaskets.
The Varex Muffler
VAREX mufflers combine both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterflyvalve mechanism is implemented to redirect the exhaust gas flow and vary be-tween the two.
For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance. Whilst for lower sound level, the exhaust flows are directed through the chambered path (similar design with the stock muffler), and produces minimum sound level that gives you the best in-car comfort.
Angle of the valve is also controllable, which can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
Street Mode
Setting your Varex muffler in 'Street mode' enables lower sound levels and maximum discretion, as exhaust gases are directed through a chambered path as would a 'stock' muffler
Race Mode
For greater power output and sound level, exhaust gases are directed through the opening path and produce maximum power with a robust sound level (or the 'sports car' note) and near-zero resistance.
"Anywhere in between"
As the angle of the valve is infinitely adjustable, it can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
http://www.youtube.com/watch?feature=player_embedded&v=h2G6A-Ya55E
: Send us a PM|||||
: NateAtMAP|||||
: [email protected]
Vendor
Discussion Starter #15
Friday is here! Looking forward to the weekend. While we are closed on the weekends, don't fear...the website NEVER sleeps! www.maperformance.com
1 - 20 of 104 Posts
Status
