MAP AFPR Install Kit with AEM Fuel Pressure Regulator (Evo X)
This kit includes a AEM adjustable fuel pressure regulator, white face Turbosmart fuel pressure gauge, fuel rail adapter, mounting bracket and all necessary fittings to accurately adjust and monitor fuel pressure in your Evo X! Includes black and silver shadow series fittings for a cleaner sleeper look under the hood!
Note: Our push-lock fuel line is black rather than blue for a low cost alternative that still maintains the stealth look!
MAP Air / Oil Separator Kit for Evo X
The MAP Evo X Air & Oil Separator Kits are plumbed into a vehicle's PCV system to capture the excess crankcase vapors and the residual oil mist from reentering the intake track. Evo's from the factory vent these excess crankcase vapors and residual oil right back into the intake manifold which could cause detonation and oil deposits to form in the intake track including the valves. The polished Billet Aluminum body compliments any engine compartment and can be chromed or powder coated for a custom look.
Key features
- Complete solution - our kit includes everything needed to plumb this into your Evo X
- Simple bolt in installation
- Billet mounting clamp to secure AOS tank to fire wall
- Bottom drain with elbow that makes draining the collected oil virtually mess-free
MAP 600hp Fuel Pump Upgrade Kit w/ DW300 (Mitsubishi Evo X)
*Also available with Walbro 255hp if desired
Introducing the highest flowing in-tank pump yet. Surpassing the competition 300LPH at a time. This pumps fits the same profile as a Walbro GSS342 for a simple drop-in installation.
Click here for more detailed information and testing results.
Also included is the MAP fuel pump installation kit to make installation a breeze! Our CNC machined fuel pump housing designed to replace the factory fuel pump/filter assembly and includes all hardware for a bolt-on installation.
- Flows 300+ litres per hour
- In-tank application specific fitment
- Ethanol compatible
- 3-year no-fault warranty
- Quiet and reliable turbine impeller
MAPerformance Phenolic Intake Manifold Spacer / Thermal Barrier
The MAP intake manifold spacer has been re-engineered from a phenolic material to avoid squishing issues that are common in competing products and yield better thermal properties. Please keep in mind that you will be spacing your intake manifold by 3/8″ and some bracketry may need to be modified.
Sealing Options:
Phenolic is a hard material and although it can be and has been used without any type of sealing device in the past we generally recommend either adding two OEM gaskets to your order below (one for each side of the spacer) or you can utilize a sealant (Type 2, copper spray, etc.) to do the job without the use of gaskets.
