Status
Not open for further replies.
1 - 11 of 11 Posts
Vendor
MAPerformance...Everything you ever wanted for suspension components and MORE!
Whiteline​
Whiteline Swaybars & Alignment products are designed to work together to deliver the best possible handling
result for your car. That's why our customers say we have "the best suspension kits in the world".
Whiteline proudly offers:
Swaybars
Alignment components
Strut and chassis bracing
Perrin Performance​
PERRIN Performance manufactures and supplies the finest Subaru and EVO products on the market today. We produce
a full line of Subaru and EVO products hitting every aspect of performance modification for your car. From
suspension to engine performance, PERRIN makes the products which will boost your performance to the next level
Perrin proudly offers:
Swaybars
Chasis
: Send us a PM|||||
: BurdAtMAP|||||
: 1-888-MAPERFORMANCE x 114|||||
: [email protected]
Vendor
Eibach​
Eibach products are created to meet the extreme requirements of racing, from the 245-mph
Mulsanne straight of Le Mans to the fender-to-fender combat of the Daytona Motor Speedway.
Eibach proudly offers:
Swaybars
Springs
Coilover Kits
Ksport​
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for
your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your
handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of
adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain
vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more
direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts
that allow it for the ability to adjust camber from the actual coilover, instead of a separate
camber kit.
Ksport proudly offers:
Coilover Kits
Swift Springs​
The purpose was to demonstrate our superior engineering in spring by developing the next generation
of motor sports suspension coil springs. They had to have the best characteristics of any brand or
design in the market, which required the springs to be the lightest in weight and most durable, and
to exhibit the most linear characteristics while still being cost effective.
Swift Springs proudly offer:
Springs
: Send us a PM|||||
: BurdAtMAP|||||
: [email protected]
Vendor
Cusco​
CUSCO/CARROSSER products are made after the strictly established standard of CARROSSER, with highest quality
upon the data from each specific vehicles, test on actual cars, and performance test.
Cusco Zero-1 Coilover Kit 2008 + Mitsubishi Lancer Evolution EVO X
Cusco Zero-1 coilovers for the 08-09 Evo X are an entry-level performance suspension system designed with ride
comfort in mind. Zero-1 coilovers feature ride-height adjustability a pre-set dampening rate. Designed for the
2008-2009 Lancer Evolution X as an alternative to lowering spring and shock combinations, the Cusco Zero-1
coilovers will eliminate bump-steer and suspension bottoming by offering a longer stroke and balanced spring and
shock combination. For reliability, the Zero-1 coilovers feature stainless steel lock nuts, spring seats, and
anti-rust coating on the shock body and springs. They are availabel with either a normal (rubber) front upper
mount (part number cus56660ECN) or front pillowball adjustable mounts and rear non-adjustable rigid aluminium
mounts (part number cus56660ECP) for improved control and feel.
Girodisc​
Girodisc is guided under the direction of company Principal Martin Meade, who spent five years as an Engineer with Porsche Engineering Services, where he played a role in developing current Porsche technology. Martin began his engineering career working in Aerospace, developing tools and components for special projects. Before working with Porsche, Martin learned a great deal about vehicle design and technologies by working with several vehicle design and development firms. Martin has developed a critical eye and will not accept anything but the best quality.
Girodisc proudly offers:
Rotors, Pads and Brembo replacement/Service parts
: Send us a PM|||||
: BurdAtMAP|||||
: [email protected]
Vendor
Discussion Starter #8
Friday! Have a great weekend, enjoy the weather and remember to check out: www.maperformance.com if you need anything over the weekend!
1 - 11 of 11 Posts
Status
