1 - 2 of 2 Posts
Hi all!
Recently got my engine built (stage 2 bottom end with GSC S2s GSC valve spring kit and Mivec delete) at a shop and I noticed that the oil galley plug next to where the belt tensioner is normally is missing! Does anyone know where I might be able to find that plug or something equivalent? (Size and thread pitch if you know it) it's really holding me up from getting my car put back together. Thanks!
I think you want Mitsu part 1050A900 with gasket MF660038
O1385Q and O1399P which is the same as the plug on the side of the block by the starter as you can see below. So if you have that one you can use it as reference or you can order the OEM part from the dealer/online.
288141
1 - 2 of 2 Posts
