1 - 4 of 4 Posts
11 gsr self tuning noob - Tp, Cbe, intake, uicp, GM 3 port and crushed BOV
Can anyone help me with getting some tables enabled for my rom. I noticed I'm missing some tables in the fuel and timing table.
Gadget Font Output device Personal computer Display device
In case you don't have the tables still now :
Code:
  <scaling name="GramsPerSecond" units="units" toexpr="x/100" frexpr="x*100" format="%.2f" min="0" max="655.35" inc=".1" storagetype="uint16" endian="big"/>
  <scaling name="VoltsADC1023" units="Volts" toexpr="x*5/1023" frexpr="x*1023/5" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint16" endian="big"/>
  <scaling name="StockXMAP in kPa" units="StockXMAP in kPa" toexpr="((x*2556/3800)+0.5)/2" frexpr="((x * 2)-0.5)*3800/2556" format="%.2f" min="0" max="350" inc="0.05" storagetype="uint16" endian="big"/>
  <scaling name="StockXMAP in psig" units="StockXMAP in psig" toexpr="((x/4)*0.19347)-14.5" frexpr="((x+14.5)/0.19347)*4" format="%.2f" min="-15" max="35" inc="0.05" storagetype="uint16" endian="big"/>
  <table name="MAF Scaling Horizontal" address="575ae" category="Fuel" type="2D" scaling="GramsPerSecond">
    <table name="Volts" address="62014" type="X Axis" elements="130" scaling="VoltsADC1023"/>
  </table>
  <table name="MAF Scaling Part 1" address="575ae" category="Fuel" type="2D" level="2" scaling="uint16">
    <table name="Volts" address="62014" type="Y Axis" elements="44" scaling="VoltsADC1023"/>
  </table>
  <table name="MAF Scaling Part 2" address="57606" category="Fuel" type="2D" level="2" scaling="uint16">
    <table name="Volts" address="6206c" type="Y Axis" elements="44" scaling="VoltsADC1023"/>
  </table>
  <table name="MAF Scaling Part 3" address="5765e" category="Fuel" type="2D" level="2" scaling="uint16">
    <table name="Volts" address="620c4" type="Y Axis" elements="42" scaling="VoltsADC1023"/>
  </table>
  <table name="MAP based Load Calc #1 - Hot/Interpolated 2010" address="60902" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
    <table name="MAP" address="63478" type="X Axis" elements="20" scaling="StockXMAP in psig"/>
    <table name="RPM" address="6344c" type="Y Axis" elements="19" scaling="RPM"/>
  </table>
  <table name="MAP based Load Calc #2 - Cold/Interpolated 2010" address="60902" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
    <table name="MAP" address="63478" type="X Axis" elements="20" scaling="StockXMAP in kPa"/>
  </table>
  <table name="MAP based Load Calc #3 2010" address="60902" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
    <table name="MAP" address="63478" type="X Axis" elements="20" scaling="Omni4barMAP in kPa"/>
  </table>
  • Like
Reactions: Lunasbuild
1 - 4 of 4 Posts
