1 - 9 of 9 Posts
Seem to be missing the below addresses on my 56910009 xml. Any chance someone could post them up?
DTC P0247 Turbocharger Wastegate Solenoid B Malfunction
Fuel Compensation MAT vs MAP - Stock3bar
Fuel Compensation MAT vs MAP - Omni4bar
Low Pulse Width IPW Adder
OBTR (Over-Boost Timing Retard) tables.
Thanks.
These addresses seem to be correct.(USE IT AT YOUR OWN RISK.)
Code:
    <scaling name="IPW_Adder_div_2" units="ms" toexpr="x/250" frexpr="x*250" format="%.3f" min="0" max="65" inc="0.004" storagetype="uint8" endian="big"/>
  <table name="Low Pulse Width IPW Adder (New Style)" category="Fuel" address="556d8" type="2D" scaling="IPW_Adder_div_2">
    <table name="Input IPW" type="Static Y Axis" elements="66">
      <data>0.000</data>
      <data>0.032</data>
      <data>0.064</data>
      <data>0.096</data>
      <data>0.128</data>
      <data>0.160</data>
      <data>0.192</data>
      <data>0.224</data>
      <data>0.256</data>
      <data>0.288</data>
      <data>0.320</data>
      <data>0.352</data>
      <data>0.384</data>
      <data>0.416</data>
      <data>0.448</data>
      <data>0.480</data>
      <data>0.512</data>
      <data>0.544</data>
      <data>0.576</data>
      <data>0.608</data>
      <data>0.640</data>
      <data>0.672</data>
      <data>0.704</data>
      <data>0.736</data>
      <data>0.768</data>
      <data>0.800</data>
      <data>0.832</data>
      <data>0.864</data>
      <data>0.896</data>
      <data>0.928</data>
      <data>0.960</data>
      <data>0.992</data>
      <data>1.024</data>
      <data>1.056</data>
      <data>1.088</data>
      <data>1.120</data>
      <data>1.152</data>
      <data>1.184</data>
      <data>1.216</data>
      <data>1.248</data>
      <data>1.280</data>
      <data>1.312</data>
      <data>1.344</data>
      <data>1.376</data>
      <data>1.408</data>
      <data>1.440</data>
      <data>1.472</data>
      <data>1.504</data>
      <data>1.536</data>
      <data>1.568</data>
      <data>1.600</data>
      <data>1.632</data>
      <data>1.664</data>
      <data>1.696</data>
      <data>1.728</data>
      <data>1.760</data>
      <data>1.792</data>
      <data>1.824</data>
      <data>1.856</data>
      <data>1.888</data>
      <data>1.920</data>
      <data>1.952</data>
      <data>1.984</data>
      <data>2.016</data>
      <data>2.048</data>
      <data>2.080</data>
    </table>
  </table>
    <scaling name="Percent_128_add_385_div_512" units="%" toexpr="(x+384)/5.12" frexpr="x*5.12-384" format="%.1f" min="75" max="125" inc="2" storagetype="uint8" endian="big"/>
    <scaling name="Temp" units="Fahrenheit" toexpr="1.8*x-40" frexpr="(x+40)/1.8" format="%.0f" min="-40" max="350" inc="1" storagetype="uint16" endian="big"/>
  <table name="Fuel Compensation MAT vs MAP - Stock3bar" category="Fuel" address="61015" type="3D" swapxy="true" scaling="Percent_128_add_385_div_512">
        <table name="MAP" address="634d6" type="X Axis" elements="10" scaling="StockXMAP in kPa"/>
        <table name="MAT" address="634c2" type="Y Axis" elements="7" scaling="Temp"/>
    </table>
    <table name="Fuel Compensation MAT vs MAP - Omni4bar" category="Fuel" address="61015" type="3D" swapxy="true" scaling="Percent_128_add_385_div_512">
        <table name="MAP" address="634d6" type="X Axis" elements="10" scaling="Omni4barMAP in kPa"/>
    </table>
  • Like
Reactions: 400s
i am also missing this following tables from 53050009.xml
Please can someone post
Hi.
It seems the tables are as below.
WARNING: It is not verified. Use it at your own risk.
Code:
  <table name="Fuel Compensation MAT vs MAP - Stock3bar" category="Fuel" address="60b89" type="3D" swapxy="true" scaling="Percent_128_add_385_div_512">
    <table name="MAP" address="62af4" type="X Axis" elements="10" scaling="StockXMAP in kPa"/>
    <table name="MAT" address="62ae0" type="Y Axis" elements="7" scaling="Temp"/>
  </table>
  <table name="Fuel Compensation MAT vs MAP - Omni4bar" category="Fuel" address="60b89" type="3D" swapxy="true" scaling="Percent_128_add_385_div_512">
    <table name="MAP" address="62af4" type="X Axis" elements="10" scaling="Omni4barMAP in kPa"/>
  </table>
  • Like
Reactions: Faheem
Hi.
Code:
  </table>
  </table>
thank you so much, i will try and see how i go, fingers crossed they are the correct for my ROM.
Hi.
Code:
  </table>
  </table>
this tables cant be use. Can u check it again?
Double checked, but as long as trusting the definitions for other ids, the address(60b89) for 53050009 should be correct.
  • Like
Reactions: Faheem
1 - 9 of 9 Posts
