1 - 5 of 5 Posts
Running Mivec deletes (magnus) intake and exhaust, having a few issues idle wise. Car runs perfect cruising but once you come to a stop it will either die or you have to keep it alive. Any one else running these with any insight that might help me get this thing on road for good?
Your idle issues began exactly after the mivec housing swap? The only thing /s changed were the magnus housings? I use a magnus mivec delete, exhaust only, but I swapped it along with the GSC S3s and I have some idle issues that go away as the engine warms up. You should check the "idle throttle air flow" map
1 - 5 of 5 Posts
