MMCS Install Question
6670 Views 8 Replies 6 Participants Last post by  splizaat
Hey, so I look around a few forums and I picked up some useful information, but I still have a few questions.
1. Which versions of the MMCS are compatible with a Lancer ES 2012? The car already comes with FUSE, so I don't want to lose any of those functions. I heard N-05 and N-04 are compatible with all functions working.
2. Is it possible to buy a 08-10 MMCS and have it work, or do FUSE equipped cars require only 2011+ navs?
3. I really just want an OEM nav, so would my best bet be waiting to find one for sale online, or going to the dealership and having them order/install everything? Does anyone know how much this would cost?
4. What are my options when it comes to installing an OEM nav on my car? Can I only use 2011+ since my car is 2012 or can I go with the 08-10 version and have a dealership adjust it?
1 - 9 of 9 Posts
It must be from a fuse equipped car or you will lose functions. Also depends on which country you get it from. I "think" the US had fuse a year earlier than Canada but it may be the other way around.
So basically I can only swap with 2011+ models?
1: N01-03 pre fuse N04-05 fuse compatible
2: N01-03 will work but you will loose fuse. If I recall correctly you will also need to purchase the pre fuse bluetooth module as well.
3: Personal preference. You need to be patient to find a N04+ unit for sale. MSRP new nav is $2200 and install kit is $450 but they can be had for less
4: really the same question as number 2.
thanks for answering them all, just wondering, since you said N01-03 will work but i'll lose fuse, is it possible to buy a fuse compatible module to make the fuse work on the older versions, or are the older versions just out of luck when it comes to fuse?
I don't think you can buy a FUSE compatible module for a '08-`10 navi, as they weren't introduced until 2011. Therefore, if you get an older navi from a 08-10 (N-01 to N-03), you will lose your FUSE compatibility.
Theoretically yes but as I understand it the wiring harnesses are different and you will need to do some wiring work. I believe this has yet to be successfully done.
i just read this while actually looking for the same answer the RA i have is 2011 with RF system and the FUSE but i just got a 2010 N-03 Navi so i will loose my FUSE if i do the swap! ^$^$%^*&^$ does somebody already found an update on this or will i loose my FUSE for good?
i have like 2 months before i actually do the swap so i have enough time to maybe sell it and try to get an N-04
regards,
G.
What about Lancers Prior!?
mine would be the 2009 Lancer GT Canadian version ,
I am not currently looking at navi but maybe aftermarket in the future ,
Rockfordfosgate version I have the oem sub
cant recall the model#
I want the fuse/ usb from the dash ,
also Bluetooth streaming
so I would need what?
Fuse headunit from a 2011+
Bluetooth module?
Usb port from dash + proper upper dash piece ? plug play plug behind in glove box?
1 - 9 of 9 Posts
