1 - 20 of 43 Posts
· Most likely in chat
I was wondering if someone could help me, ive never had this problem before. Drove 12 hours from Edmonton to BC, the MMCS head unit was fine, could play movies, sound worked etc.
Ive been in BC a couple days now, all seemed fine but this morning I tried to play some music and noticed that the sound no longer works. I made sure it wasnt muted.
Movies, music, beeping sounds all do not work now. Any ideas?
Ive already checked the connections to the head unit through the dash, those all seem to be good.
Discussion Starter · #2 ·
I pulled the 30 amp fuse under the hood as well as the 15amp fuse in the dash,both are fine. Swapped them around anyways and still same issue, head unit works but no sound whatsoever.
I pulled the radio to check all the connections and all was good. I haven't been back there in a long time.
Only thing I have done is added the fuel injectors and fuel pump. Both of those aren't near the radio.
Everything on the Navi works, the screen, navigation, I can see the music server counting the seconds on the music. I can switch radio stations.
Just no sound. Dead silience. When I pulled the radio I looked for some fuses but didn't see any. Was hoping there was one on the back that was blown or something.
Well it seems if I turn on the car quickly the radio works. If I turn it on and leave it at accessory and let the radio boot then start the car, I get no sound.
Not sure what the deal is, but I got sound which is all that matters.
1 - 20 of 43 Posts
