1 - 5 of 5 Posts
Administrator
I'd like to use this thread as a guide for MUT-III/VCI owners looking to perform common tasks. Please keep this thread clean and only post instructions and tips on how to complete a given task.
To retrieve/edit TPMS sensor IDs:
  1. Launch MUT3 program.
  2. Select "System select".
  3. Enter type/year of vehicle under vehicle selection.
  4. Connect computer to VCI and to vehicle (blue cable), switch vehicle ignition on.
  5. Select 15 - KOS/IMMO/Keyless; a new options list will appear.
  6. Checked the appropriate options set for your car. For example, Fastkey owners will check the box "VF2 - IMMOBI & Keyless & TPMS".
  7. Click Check mark icon on green toolbar at the bottom right
  8. Select "Special function".
  9. Choose Pressure Sensor ID Registration, Tire Pressure Sensor ID check, etc.
Why oh why didn't I use the blue cable?
  • Please note that when using the VCI (Vehicle Communication Interface) on an Evo X, you should always be using the OBD-II cable with the blue end.
To program a VIN to an ECU:
  9. Choose "ENG Key Code &Chassis No/VIN Reg"
  10. Click Check mark icon on green toolbar at the bottom right
  11. Enter the chassis VIN you want to program the ECU to
  12. Click Check mark icon on green toolbar at the bottom right
Administrator
Discussion Starter · #2 ·
How to Program FAST Keys:
  1. Select the "System Select" button
  2. In the System List, select KOS/IMMO/Keyless
  3. Select the "IMMOBI & KOS & TPMS" checkbox
  4. Select the "Special Function" button
  5. Select Key & KOS key Reg.
  6. Remove the plastic key nub.
  7. Enter the password 8A12 and hit the check mark
  8. Insert the metal key into the ignition with the FAST key attached to the back.
  9. Click the check mark to begin the key programming
  10. When complete, turn the key off and remove the key.
  11. Insert any subsequent keys and repeat steps 8-10 to program them
  12. Now it's time to register the fob. Press the check mark to begin the operation.
  13. With the first fob in your hand (no longer in the ignition), click the lock button twice, ensuring that the red light blinks with each press. When you do it successfully, the car will beep, and the KOS Key Registration on the MUT-3 will increment.
  14. Repeat the previous step until the Registered Number of Keys matches the Registered number of KOS.
  15. Wait a minute or so and pray to the car gods for success.
1 - 5 of 5 Posts
