21 - 31 of 31 Posts
Honestly I understand the debates on how to fill these diffs (fill plug vs drain plug debate), measure the fluid prior to factory given amount, add a tad bit more for reassurance then pump away.
Personally I fill from the fill line, but i also make sure to spin the tires after it weeps, allow it to rest, then continue filling until it consistently comes out the fill.
Discussion Starter · #23 ·
Finally replaced my Upper Tie Bar. Stripped the nuts out trying to remove broken bolts.
Then jumped on installing the JDC Bumper Quick Release Kit
Messed up my first go around, but bumper is going to get the license plate holes filled anyway so i'll just have them fix this too.
Closer look at my impatience
Discussion Starter · #24 · (Edited)
Hey guys, a little update on the Evo, I haven't really done anything "spectacular" to the car, besides a impulse buy here or there, I have just been driving it and enjoying the car. Making up for all the missed time after blowing the stock motor (354whp) 4 months into owning the car. Still haven't experienced any benefit of having a built motor due to be restricted by stock fueling & stock turbo. I did begin to hear a faint tapping sound coming from the trans that went away when i push the clutch pedal. So of course I thought TOB but after popping the hood, I noticed the Radium clutch fork stop needed to be adjusted (Radium says that it will need to be adjusted over time). Got that taken care of but the sound was still there. So me thinking maybe it bent the fork or TOB (Learned my lesson, they mentioned it for a reason). Got those ordered, but it began to get difficult getting into 2nd gear eventually locking me out of all gears. Not willing to risk wasting $1k in labor for something as small as a tob or fork, I decided to change it myself.
Should have taken this as a sign, the axle nut was not playing nice, broke two breaker bars & embarrassed my handy dandy ryobi impact gun.
Ended up buying a Milwaukee Impact..... Smooth like butter!!!!
Got the TOB disengaged with no issues
After unplugging the everything in the engine bay, I found what looked to be gear tooth when I drained the trans. Figured since the car will be down I might as well throw make space for those impulse buys.
NEVER AGAIN!!!
So exactly a year to the day that my rear diff failed, my trans has decided to follow suit. Going to send it out to SHEP to get rebuilt while everything is off. Also need to get the hot parts coated, & heat protect misc lines. Maybe I can talk myself into installing it.
Discussion Starter · #25 ·
Finally got the ShepBuilt Trans back some time ago, I have just been slacking on updates
Here is a pic of the damage
Today I finally got around to fixing the brake lines that snapped when the caliper fell when dropping the trans
If you need to ever remove the trans again, leave the knuckle, brake assembly etc assembled, and remove the LCA ball joint from the knuckle instead.
You have less components to take apart, less to put back together, and less to go wrong
Discussion Starter · #29 · (Edited)
Been busy these past couple of days. Really decided to dig into the car for about a week straight in between my work schedule.
Radium Fuel rail with damper & pressure gauge
Omin 4 BAR
AMS Lower Piping with Tial flange
Radium Fuel Feed & Return Lines In
OEM Galant/Spyder GT 65mm TB
Sitting Pretty, 65mm Ported IM to match is on the way.
ETS Twin Scroll Kit
Tial 50mm
Full Engine Compartment Titanium Kit
Ti Everywhere
Speed Circuit XXL Heatshield is a tight fit but it works with little adjustments.
Snail is in!!!!!!
Discussion Starter · #31 ·
Received my tactrix cable today, and was to pull my current tune from the ECU (Locked, of Course). I was able to get ahold of a stock rom for my car as well. Going to play around with trying to scale id 2600's just for fun until I can get scheduled for a proper retune. Been reading Merlin's Guide, stalkingthe turn sub-forum, and watching some videos to get a basic idea, seems very overwhelming but I'll get the hang of it sooner or later.
21 - 31 of 31 Posts
