I found a pretty good definition on Wikipedia lol:
A
chicken strip is a sometimes derogatory term used to describe the width of unused tread on the edges of
motorcycle tires, typically a sport bike.
A turning motorcycle must lean into the turn. The faster it is going or the sharper the turn, the farther the motorcycle must lean over. For a formula relating speed, turn radius, and lean angle, see
Bicycle and motorcycle physics. As the motorcycle leans, the tires'
contact patches move farther to the side causing wear. The
chicken strip is the amount of unworn tread caused by a motorcyclist being considered too chicken to go faster through a turn and thereby lean the motorcycle farther over.
This is frequently used as a
derogatory term deriving from the term
chicken. Hence,
chicken strips mark an inexperienced motorcyclist who is afraid to lean a motorcycle far enough to wear the edges of the tire. It should be noted however that due to the handling capabilities of many modern motorcycles, and the vagaries of road condition, it is not advisable to exploit outer handling limits on public roads. The bike is typically capable of handling corners far too fast to avoid a sudden obstacle (car stopped or run wide, etc). On a closed race circuit, however, a rider is expected to use the edges of the tires on turns in order to stay competitive.
