Hi all
I have a problem with my mmcs. Things I have done:
- Downloaded the following file:
http://rapidshare.com/files/38801905...4011.NODVD.ISO
- Burned it and put it in my mmcs
- Pressed "yes" on the display
- The mmcs restarted and I got the following message:
"The HDD doesn`t work. Turn off the ignition key and try again"
- I took out the CDRom and turned on the mmcs again, then the message "Insert Program Disc" appeard.
- Every Time I tried it with the iso/cdrom again, I got the same message "The HDD doesn`t work...."
- I put the HDD out and linked it with the pc. Then I realized that the HDD was dead. (Don`t spinning anymore)
- I took another HDD, restored the ghost image and tried the same process again. No luck, same message.
- Could someone tell me where the problem is?
- Could it be, that the mmcs is not able to lock a "unlocked" HDD in this state. (Not booting, just give this message)
- How can I lock the drive manually?
- Should I try a "Cold Boot"? (unplug battery for some time)
Hope you can help me, it drives me crazy.. Thanks
By the way, the mmcs sw infos:
SW-Version: F
MapVersion: 2006-1
CDDB-Version: 0663-0000
Loader: BLD-NR-261EM 1.09
Application: 00.31.06
Navi Sub Microcomputer: 00.30.00
Audio Microcomputer: 00.30.00
Map Data: M110 AEU_07_200701B
Monitor: 00.27.00
CAN Box: 000120
Best Regards
mrnice
