1 - 3 of 3 Posts
Hi all! I have a 2012 X MR with MMCS/NAV. Works fine and it remembers every setting I set in it, except the clock settings. It won't remember clock region ( Eastern, Western, Central, etc.). It won't remember Daylight Saving Time ENABLE/DISABLE either. I tried a battery reset. I tried searching in the secret menu to manually change GPS time, and it keeps reverting back to one hour behind the actual time. Any of you know the fix to this ? Thanks.
There is a setting for daylight savings time. Turn it on or off.
My N-12 Navi in my 2015 has DST as well. If I recall, you have to manually select it during active DST months, it will not change on its own. When active, it will roll your clock back one hour.
You may also have to change geographical settings to allow you to set your time zone individually. Try using a different time zone. Select the zone that best represents your current time based on actual clock data, and not the zone label. My current zone is Indiana (-5) but it is labeled as something completely different and not at all correct on the clock data.
1 - 3 of 3 Posts
